Beetle radiator and looking stock
Posted: Wed Aug 30, 2023 1:02 pm
by Meresider
Over winter fitting EJ20 and obtaining all parts beforehand. With a non turbo what is the smallest radiator anyone is running, also is there an option to keep as much of original wheel well as possible as want to keep it stock looking. Planning on cutting away at rear of radiator adjacent to fuel tank as recommended but would like to have the minimal scoop on the front. Cheers...
Re: Beetle radiator and looking stock
Posted: Tue Sep 05, 2023 5:48 pm
by vw1970
I may hold the title as smallest radiator in a Subaru type 1. Basically a $60 honda cicvc ebay radiator turned on its side and chopped down a bit to be about 12"x 12" of cooling area. Ive been testing this over the last few weeks and it seems to work well.
IMG_20230623_160156 by
Travis L, on Flickr
Posted: Wed Sep 06, 2023 3:29 pm
by MikeGyver
Looks like an interesting Bug. Can you post more pictures of the whole car? How did you run the coolant lines? I'm working on a JDM EJ20 N/A conversion right now.
Posted: Thu Sep 07, 2023 6:26 am
by vw1970
yeah, I'll grab some more this weekend as the radiator setup has changes slightly since the previous picture.
Are you using the JDM ecu and harnesses?
Posted: Fri Sep 08, 2023 5:05 pm
by MikeGyver
I'm using the Speeduino standalone....I hope! It's a few football fields out of my comfort zone.
Posted: Sun Sep 10, 2023 2:37 pm
by vw1970
The car has a weird 2005 legacy "PZEV" DBW ej2.5 SOHC engine that originally had 5 o2 sensors. I didn't like that so i swapped the ECU for a forester DBW ECU which I can run one single o2 sensor now. Being the engine itself was in a PZEV car, it has an unusual oval port on the heads that you can see in the photo of the header here:
IMG_20230910_130409 by
Travis L, on Flickr
Here is the front shrouding setup after adding a final piece to span to the hood and a few holes cut in front for air into the radiator.
IMG_20230910_130305 by
Travis L, on Flickr
here are the coolant lines under the car:
IMG_20230910_130355 by
Travis L, on Flickr
Posted: Sun Sep 10, 2023 2:39 pm
by vw1970
here are just a few more pics if you are curious.
IMG_20230910_130225 by
Travis L, on Flickr
IMG_20230910_130155 by
Travis L, on Flickr
IMG_20230910_130213 by
Travis L, on Flickr
IMG_20230910_130518 by
Travis L, on Flickr
Posted: Sun Sep 10, 2023 9:02 pm
by MikeGyver
Right on! Thank you for the pictures. How loud is it with that muffler?
Posted: Mon Sep 11, 2023 5:45 am
by vw1970
its pretty loud but no louder than an air cooled bug with a "phat boy" side exit muffler. Has a nice throaty note.
As far as using the speed-uino, there will be a pretty big learning curve to get it work right coming from someone who started with a mega-squirt back in the day. But if you have the patience and know a bit about tuning then you'll have a great time with it.
What car are you putting the ej20 into?
Posted: Mon Sep 11, 2023 1:29 pm
by MikeGyver
I'm aiming for a more quiet ride. This will just be an ugly around town cruiser. It's a '63 Bug.
My hope is that the TunerStudio auto-tune feature will be able to do most of the work. My goal is to have it running by next summer. The transaxle is the hold up at this point. It was a nightmare trying to find someone to build me one as the one that came with the car was toast. The builder said the lead time was 4-6 weeks, and this is week 6.
Posted: Mon Sep 11, 2023 3:25 pm
by H2OSB
Perhaps this is a bit late, but Scott from MetalCraft Motorworks in Sangar, California does great work and can rebuild any year box. His prices are incredibly fair as well.
He's MCMScott on here. He rebuilt my IRS box and while I was there to pick it up, I watched him work on a SA box out of a desert race car. He ships all over the world, too.
H2OSB
Posted: Thu Sep 14, 2023 1:13 pm
by vw1970
MikeGyver, a better muffler and or a resonator would help my setup for sure. If you plan to build a system i'd recommend a same side inlet outlet muffler as they seem to drop the growl quite a bit.
When start getting it together definitely document your build for the forum her, we'd love to see it!
