72BajaBen Baja Rebuild Thread
blue1957
Re: 72BajaBen Rebuild Thread
Post by blue1957 »
looks good. I plan on using it as well. I used it on my 57 pickup on the underside of the cab and fender wells. Great stuff.
Looks nice, good job you two. What’s next?
72bajaben
Post by 72bajaben »
blue1957 wrote: Thu Dec 09, 2021 4:33 pm looks good. I plan on using it as well. I used it on my 57 pickup on the underside of the cab and fender wells. Great stuff.
Yea it’s pretty awesome. I would 100% recommend it. You can get it in a tintable version so you can make it just about any color you want. I’m about 90% sure I’m going to spray the entire body with it.
72bajaben
Post by 72bajaben »
Leatherneck wrote: Thu Dec 09, 2021 5:14 pm Looks nice, good job you two. What’s next?
Next is 5-7 days of curing. Then we make it a roller again. Front and rear suspension are going on. Then it’s on to body and cage I think.
blue1957
Post by blue1957 »
72bajaben wrote: Thu Dec 09, 2021 5:36 pm
I was going to use in on the interior and the underside of the body. Definitely good stuff.
When you go to make changes or repairs, how hard to scrape/grind off?
Leatherneck wrote: Fri Dec 10, 2021 7:02 am When you go to make changes or repairs, how hard to scrape/grind off?
:wink: :lol:
72bajaben
Post by 72bajaben »
I’m sure it’s going to be a bitch. But I don’t think it’s any match for a 40 grit flap wheel or a nice twisted wire cup. Lol
That’s good and bad. I’ve got to take my buggy down and do some painting on it. Oklahoma humidity is just a wee bit more then Arizona.
72bajaben
Post by 72bajaben »
I think I'm going to turn the baja Yellow like it was originally.
72bajaben wrote: Sat Dec 11, 2021 7:51 am I think I'm going to turn the baja Yellow like it was originally.
Doesn't "yellow" mean your afraid? Bwahahah :lol: :roll: :wink:
I usually think of darker colors when one is out in the sun but then one car can be harder to see with the darker colors. Kind of a "Catch 22" isn't it. ("Situation in which an action has consequences which make it impossible to pursue that action.) A dictionary definition.
catch-22, catch 22
72bajaben
Post by 72bajaben »
So while the bed liner cures I had another project I needed work on. Ive been putting it off for a few months since it was kinda buried in the back corner of my shop.
So here is my Shapeoko 3 CNC Router. Im upgrading the Z axis and spiondle.
I forgot to take a pic of what I started with.
But here is the machine torn apart.
Electronics box
Here is the new 1.5kW (~2hp) spindle. Its going to be a HUGE upgrade from the like 1/3 hp router.
Here the machine is all assembled again.
And my new desk. LOL
Today I need to solder the spindle connector and run a 220v line over to the machine. I'm waiting on a VGA to HDMI cable coming Monday before I can fire it up.
I also couldn't help myself. I assembled the front suspension. Shock tower is welded on.
Trans has also been cleaned up.
Not too bad for 1 days milling around the shop.
72bajaben
Post by 72bajaben »
Ok...The barrel wasnt cutting it and I couldn't wait for the cable to come.
So 32" tv is the new monitor. The machine is fully up and running. I still need to test the laser module.
Ok...Back to my regularly scheduled project.
72bajaben
Post by 72bajaben »
I got the rear arms mounted and the rotor and stubs in. Nothing is super tight yet. But its nice to see parts off the shelf.
I almost feel like I'm missing a spacer...but I dont have any spare parts in the bins. So thats something I'm going to look into.
