WTH?
WTH?
Thoughts?ImageImageImage
Sent from my SM-A102U using Tapatalk
baja5
Re: WTH?
Post by baja5 »
That’s one way to keep your back seat.
Re: WTH?
I think it started with a swing set?
Re: WTH?
It's and interesting design idea...
... assuming the rear tube is attached the same way, the side bars, that are attached to the door frame/structure, could end up being a problem causing the door frame to distort then jam in some hard riding.
Also, that structure probably isn't doing what it is wanted to do (w/o seeing more).
Opinion.
Wolfin
Re: WTH?
Post by Wolfin »
See! That's what happens when you give your woman a say over how your car is going to be built! I was building my Trail Rail with my Wife's capable assistance when she noticed that there were no doors. Uh oh! says she! No no no no says she! I must have a door to get in and out says she! No no no no door says I. You can't have a door in a rail says I. Back and forth for a few days. I finally gave in and installed doors in my Trail Rail! I mounted Debris nets over the side openings! Bwahahaha.
Re: WTH?
Wolfin, I feel your pain. Mine wants easier access to get in our rail too. Gotta figure out a way I keep her happy. The Baja above, uh not sure about that setup.
Re: WTH?
Wolfin wrote: Fri Nov 26, 2021 8:05 pm See! That's what happens when you give your woman a say over how your car is going to be built! I was building my Trail Rail with my Wife's capable assistance when she noticed that there were no doors. Uh oh! says she! No no no no says she! I must have a door to get in and out says she! No no no no door says I. You can't have a door in a rail says I. Back and forth for a few days. I finally gave in and installed doors in my Trail Rail! I mounted Debris nets over the side openings! Bwahahaha.
Be careful with what you say... your wife might read it and then want a door between the two of you opening towards you (slammidy, slammidy, slam!)... and that would be a tight fit :roll: :lol:
