Got about 50 miles on it now, it was running ok on my first drive but towards the end it started missing under load like it was running out of fuel
https://youtu.be/b5eotWVvO6k
So I started with the carb(28 pict)
To get it to idle above 500 rpm the screw for the throttle plate had to be screwed way in and it was uncovering a progression hole.
So I put a 30 pict 1 on it and it ran better, idle speed screw was left right where it was before and it idled perfect right around 750-800rpm. Went and took it for a drive and it was still missing but more frequently.
Got to thinking figuring it had to do with spark, new cap, rotor, wires and plugs. I serviced the 009 and it has a 4 year old 6v pertronix, only thing left was the coil. Put a new one on and wallah purrs like a sewing machine:)
It's a good runner for sure, and very dry with the exception of 1 small leak on the oil pump/cover(1 or 2 drops after shutdown, no complaining here. Did a little run on my dragracer app on my phone and here's the results
