Gauging Interest - Return Of Pauter Rockers
I've been in talks with the Pauter staff, and was able to get a quote. At $1000 a set, do you think there'd be interest?
Features:
1.48 ratio
Elimination of the needle bearings - direct rocker to shaft
Splash oiling for shafts, exactly like new T1 rockers
7050 aluminum instead of 7075
In the past, the oil channel was a weak point for the rockers, so new versions will still have a through-drilled adjuster to fling oil around in the rocker box.
Trying to see if I should revive these, or let it die.
Features:
1.48 ratio
Re: Gauging Interest - Return Of Pauter Rockers
Hi!
Maybe for the American market this might be interesting but in Europe we have the ratio-rockers made bei Weiss.They come in at 850Eur.After import duties and currencies that will probably exeed 1000 US dollars.
http://www.weiss-automotive-products.com/kipphebel.php
Yep. I have a set. He's redesigning them now, and I'm excited. The European market still seems like a strong candidate because of beliefs about swivel adjusters and Pauter's reputation. When I see bids on used rockers, they easily exceed $1000. I'm thinking Norway, Sweden, Australia, and Germany still are viable markets. Norway has a historic class, and everybody seems to be running ratio rockers of some sort.Arnoud wrote: ↑Sat Mar 27, 2021 1:27 am Hi!
I think they would sell well with those improvements you have mentioned
Have you thought about increasing the ratio at all? 1.6 or 1.7 not sure if this would cause any issues with clearance etc
The redesign would cost too much. I'm don't have much input. Pauter still has the tooling, and would use knowledge gained from their T1 rocker feedback
- Ephry73
Any updates?
- dstar5000
stupid price gouging..
"Let me say it as simply as I can: transparency and the rule of law will be the touchstones
- dstar5000
For $1000,I can machine 3 sets for myself. Shame.
DON
DON
Not at all. They were $650 twelve years ago, and now materials prices are higher, they'd have to restart production, and inflation is always present. You do the math.
You can make two sets of special alloy rockers sets with rollers, shafts, mounts, and hardware for under a grand? Have at it....
- Ephry73
Would be nice to have something robust like that and the higher ratio.
