Weber ICT parts
H2OSB
Weber ICT parts
Post by H2OSB »
Greetings--
A couple years ago I picked up a gently used set of Weber ICTs because they were cheap. I've recently completed my first AC engine, a 1641, which I think is the perfect place to use the ICTs. Due to not liking the cross bar linkage, i bought a Scat bell crank set up for the carbs. However, it has just dawned on me, without the cross bar linkage brackets, i have no place to attach to return spring to, since I purchased the carbs with the linkage installed.
Does anyone have those two little brackets that come on the carbs, they'd be willing to sell to me? I could not find them available from ICT parts vendors.
H2OSB
