Hi STF , How can i use my super Beetle transmission into my 912 engine?
What are the modifications and parts i need to purchase so that this conversion will work,my first attempt was failed.
Clutch doesn't move,
Thanks for the inputs
912 engine into a super Beetle transmission
Re: 912 engine into a super Beetle transmission
what flywheel are you using ? did you install the pilot bearing ?
What throw out bearing does your trans use?
How are you actuating the clutch?
Photoshop??
