Going Honda
Re: Going Honda
A Master Honda Tech at work, seriously this thing needed to be beat into submission.
https://youtu.be/7NywgpRcRNs
[youtube] https://youtu.be/7NywgpRcRNs[/youtube]
[youtube]https://www.youtube.com/watchv=7NywgpRcRNsfeature=share[/youtube]
[bbvideo] https://youtu.be/7NywgpRcRNs[/bbvideo]
baja5
Re: Going Honda
Post by baja5 »
Hey, sometimes it doesn’t have to be pretty to get the job done.haha
Re: Going Honda
To paraphrase "Murphy's Law": Anything that can go wrong will go wrong and usually at the most inopportune time. :roll: :wink: :lol:
At least you are getting somewhere where I am not.
Re: Going Honda
baja5 wrote: Sat Oct 03, 2020 9:37 pm Hey, sometimes it doesn’t have to be pretty to get the job done.haha
And we got the job done. BTW the ground is helping. The first turn of the key is slow but after that it spins like normal. Will replace the battery, I’m sure that will help.
Lee, on this build that quote is for sure true. But we got lucky too.
Re: Going Honda
Leatherneck wrote: Sun Oct 04, 2020 8:02 am
If you so search on luck you get quite a few positive and negative quotes on it but I picked up somewhere (a long time ago) that "luck is what you make of it".
Be neat, be tidy and keep your eyes open looking for places where luck is hiding. :shock: :lol:
Re: Going Honda
The throttle body I had had no MAP sensor on it because the previous guys had really Frankensteined it. So looking for a sensor was just about pointless. Denny said let’s go junkyard shopping. Went to Needles junkyard the only V6 Honda they had was off limits so took one off of a 2.3 4cyl. Guy said it wouldn’t work, Denny said we are tryin it. $10 for the used $69 at the cheapest parts house and Honda at $175 and a week out. We got lucky and it worked.
baja5
Re: Going Honda
Post by baja5 »
And it runs smoooooth!
Re: Going Honda
Leatherneck wrote: Sun Oct 04, 2020 6:30 pm .... We got lucky and it worked.
:P (smirk!)
Devastator
Re: Going Honda
Post by Devastator »
RIGHT ON! Always good when the thing runs.
Devastator's Build Thread
Sandrail
going fast enough."
Mario Andretti
CentralWAbaja
Re: Going Honda
Post by CentralWAbaja »
Leatherneck wrote: Sat Oct 03, 2020 5:09 pm A Master Honda Tech at work, seriously this thing needed to be beat into submission.
This is the same guy I called for advise! I like his style.
Re: Going Honda
CentralWAbaja wrote: Mon Oct 05, 2020 12:41 pm
Joe and Denny are friggen wizards with this stuff. Man they eat a lot though 😂😂😂
baja5
Re: Going Honda
Post by baja5 »
Man, I only eat like that at your house Leather, if only my Mrs. could cook like that.......
jt1967
Re: Going Honda
Post by jt1967 »
EAT TO MUCH DANG THAT HURT!!! I GAINED 5 POUNDS THOSE 2 DAYS FROM ANGIE'S AWESOME COOKING :shock: :shock: :shock: :shock:
That new motor Puuurrrsss like a kitten! on the test drive Leather turned the corner and chirped the tires :roll: :lol: :shock:
Re: Going Honda
I cleaned up the ground, haven’t added the other engine ground yet but before I disconnect the ECU it spun a lot faster. I ordered that battery, posts and hold down so that should also help the starting. Does anybody know the hp or kw of a stock 091 starter?
Lol, when I chirped the tires that was after the clutch was let out and gave it a little gas 🤩. Hopefully this weekend will take it out in the desert. 😎
Re: Going Honda
Leatherneck wrote: Wed Oct 07, 2020 7:50 pm I cleaned up the ground, haven’t added the other engine ground yet but before I disconnect the ECU it spun a lot faster. I ordered that battery, posts and hold down so that should also help the starting. Does anybody know the hp or kw of a stock 091 starter?
Leather, I don't know the HP of the starter but the bus setup required battery is a bigger healthier unit. I had problems battery problems with my buggy once and I went down to the battery place and the guy said that the bus trans/starter demanded a different battery. I bought one and haven't had problems since. I do keep it on a mini-charger also.
