Is it right
Buildingbob
Is it right
Post by Buildingbob »
Building a motor have a stock 1600 case 74mm crank, 100 cam 88mm slip ins 5.325 rods, 1.25 rockers 90.5 heads 40/35 valves 1 1/2 inch side winder exhaust and dual empi 34s any suggestions
Buildingbob
Re: Is it right
Any suggestions
V8Nate
Re: Is it right
Post by V8Nate »
What are you looking to do? A set of IDF's would be better than the ict knock offs but they will work if that's all you have they will just limit your performance
Buildingbob
Re: Is it right
Pretty much just a daily driver freeway once in a while no racing
V8Nate
Re: Is it right
Post by V8Nate »
That combo will be better than stock:)
