Basic specs are
2270cc
New 914 heads, 44x38mm Manley valves, ported, 7.7:1 CR
ARP head studs and rod bolts
78mm DPR crank
Cunningham H beam rods
Custom forged 96mm JE pistons
Custom Web cam on 112LC
Lightweight type 1 lifters
Manton pushrods
Double valve springs
Dry sump oiling
EFR7670 Turbo - some nice A/R advise from Wally - thanks dude!
DTA S60 ECU
Chargecooler made from a S3 intercooler.
911 upright cooling because it looks nice. Again not the topic of this thread
KEP 915 flywheel and Porsche HD lightweight racing clutch
This is my first engine build, so I'm learning as I go.
I came up with the spec, but I must admit I've had some advise from Stateside tuning here in the UK to reign things in a bit, and JC did my case machining and balancing for me. He's a top guy.
I've done everything else.
The target is >300BHP. I'm not sure how I arrived at that number, it felt right.
I cleaned everything three times then put stuff together with assembly lube
Some pics
Crankcase after line bore, sleeving for lifters etc crank built up with rods Crank in the case Some parts
