Hi everyone, I'm rebuilding my tired 1.6 dp engine from my 73 superbeetle and the cam gear is worn. I have a spare 2.1 dj cam and I'm thinking to put it on the engine. I'm going to put the 26mm wbx oil pump too.
Other than this, the engine is going to run stock, I'ts going to be a temporal engine because I want to build something bigger (like a type 4) but I need running this engine as soon as possible with the less expense, that's why I thought this setup.
What do you think? Maybe I can put a bugpack header that I have, just I'm not sure where it is
The take up ramp is different between solids and hydraulic by design. Of course they look alike, it is a camshaft.
In a word, no. Steel is normal for hydro-cams, I doubt the length matches between the two. While most factory rocker arms used larger adjusting screws w/ hydros I doubt it is absolutely necessary. The dual springs I suspect are mandatory.
