I'm in the process of turbo'ing my engine and have the fuel pump out, the pump rod in the engine have a sharp ball like tip and the other old one I have laying around have more of a cone and a flat tip.
The flat tip version are a few mm shorter.
I would think the flat tip would be better as it has a bigger surface and therefore distribute the load on a bigger surface!
Old school fuel pumps for "generator" engines used a 106mm length pushrod, newer engine with "alternators" use a shorter fuel pump and 100mm pushrod... New short rod fuel pumps also has actuation arm that comes down below the bolting flange...
(Image from J bugs site)
Cant mix and match with out problems...
Dale
Well I'm at it again and have been giving it some thought, maybe others could find my thoughts useful.
The surface on the drive is sloped so I opted to go for the pointier version as I thought the flatter version would still only have a small surface contact due to the slope of the drive. Problem solved until new evidence appears
The reason for giving this so much thought is my plan to make a dual mechanical fuel pump setup for my turbo build.
