Off topic: new vw dsg7 dq200
mads b (dk)
Post by mads b (dk) »
Hi in denmark we are experiencing trouble with the dq200 dry clutch 7 speed gearbox..... vw is trying to convince us that it's a local climate problem.... they are saying that it is moisture on the clutch
The problem is that the clutch for 1-3-5-7 gear is sliding.... when driving slowly you can see that the tachometer it jumping in very small steps.... when driving in 3 or 5 with full throttle the tachometer jumps 200-300rpm....
Have any of you seen this problem?
Sendt fra min SM-G935F med Tapatalk
mads b (dk)
Re: Off topic: new vw dsg7 dq200
Log I have madeImage
mads b (dk)
No one with a new vw daliy family car.... Skoda ? Seat?
Year 2014-2017
Pablo2
Post by Pablo2 »
No, this is essentially an air-cooled forum. Good luck ..
aka Pablo, gears, Geary
9.36 @ 146 in '86
mads b (dk)
Pablo2 wrote:No, this is essentially an air-cooled forum. Good luck ..
Yes I know it's alongshot..... but I drive an aircooled and a new car with dsg7 transmission...... I can't be the only on....?
Bruce2
Post by Bruce2 »
Does it do it in 2nd, 4th or 6th?
TZepeSH
Post by TZepeSH »
Can you get out of the log the oil pressure for the clutch? If it is moisture, I think it shall be observed both for 1-3-5-7 and for 2-4-6-R, not only for one of them. I'll try to ask if this is a known issue from the ECU, I work in this domain. I do not understand the difference between Group358 and 359, I do not know of a transmission input speed shaft and two others separately (Input speed shaft 1 and 2). Normally on transmission you have only ISS1 and ISS2 and maybe output speed shaft, and transmission input shaft could be the engine RPM.
mads b (dk)
TZepeSH wrote:Can you get out of the log the oil pressure for the clutch? If it is moisture, I think it shall be observed both for 1-3-5-7 and for 2-4-6-R, not only for one of them. I'll try to ask if this is a known issue from the ECU, I work in this domain. I do not understand the difference between Group358 and 359, I do not know of a transmission input speed shaft and two others separately (Input speed shaft 1 and 2). Normally on transmission you have only ISS1 and ISS2 and maybe output speed shaft, and transmission input shaft could be the engine RPM.
I haven't seen a group with oilpressure.... but group 9 show the dutycycle on the valve that's controlling the clutch pressure ...
Group 358 it actually engine rpm
Group 359 is rpm on input shaft 1 (1-3-5-7gear)
The picture log is made in 3 gear...
mads b (dk)
Bruce2 wrote:Does it do it in 2nd, 4th or 6th?
No problem in 2-4-6 gear
Bruce2
Post by Bruce2 »
I would ask VW to explain how a damp climate knows what gear you're using.
mads b (dk)
Bruce2 wrote:I would ask VW to explain how a damp climate knows what gear you're using.
Ha.... yes good question.... but some of us with problems, have found that on Cyprus a very warm an dry place..... there are also some vw drivers with the same problem.
I think some of you are located in USA, is this a problem in the warmer states.... or at all in USA.... I think Vw is a bit more scared about having bad products "over there"
mads b (dk)
I have been searching vw dealers in Canada, Texas and California.... and for example the Vw jetta 1.4T 2017 is only with a 6 speed autobox and I believe that is is not even a DSG autobox....
In Europe the only autobox you can get with a 1.4T engine is a DSG 7 speed dry clutch dq200
foowie
Post by foowie »
mads b (dk) wrote: Wed Sep 06, 2017 11:16 am ...
Hi, were you been able to resolve this issue? I'm experiencing same behavior.
