There are now press-in bushings available from TP in Germany: http://www.tp-technologie.de/produkte%2 ... n%20en.htm
I've used them-I didn't even heat up the case just pulled them in with a threaded rod and some washers.
Their tool steel lifters are well priced as well, esp with the current US/Euro exchange rates.
Wonder what the translation of "lifter bores lowered by 7mm" means..
I'm guessing that it means facing so the foot has clearance at lift.. Right?
Thats how I read it
If you have a really high lift cam you still need to check, but you can always cut after the bushings are in, as long as you can also cut for the lifter head lower radius... The bushings likely have that built in.
