Just to confirm, if I'm running a MSII 3.57 and single-wire oxygen sensor, this is narrow-band and MS would not be able to adjust AFR? Correct?
The AFR readings would just be for reference to tune the VE, correct? Thanks.
Quick question about EGO *Searched*
Re: Quick question about EGO *Searched*
If you have your AFR target table all set to 14.7:1 it will be able to tune your VE table reasonably well.
Have not tried it myself, but as it exists it likely works.
You can get a very good wb these days for <$100 so the NB feature probably doesn't get tested much
