Iam back with more trouble, seems like this engine is going from badluck to badluck...
After changing the alternator and installing a new set of plugs because some did not fire a nice spark, i took the bus out for a quick ride.
Fuel up with super and took the highway, ran fine, took a small road to get to a campground (about 70 miles away from home and in another province) it started fumbling like it had no power when there was a load.
Stop in a parking, stop the engine, did a visual check, started the engine and it seemed ok, so i drove on to a narrow bridge where it died going a slight hill (worse place ever to be stuck....)
Someone pulled us to the campground and the next morning i checked the valves and plugs, it all seemed ok but it would not start (crank but nothing happens).
Got back home with the tow truck and now iam a poor fellow...
What i tested so far:
Checked the fuel pump , detach the out hose and had the fuel pump running in a glass container, plenty of pressure and the gas is nice.
Check the signal in tunerstudio and the cranktrigger is doing its job and i see the idle go up when cranking.
Checked one of the sparkplug and it does fire up nicely
So it has fuel and fire and the megasquirt seems to have the info it need but nothing happens at all when cranking.
My next test is to try after of the fuel regulator to see if the pressure and flow is ok. I will try that but after i dont know what to check.
Any taughts?
1971 bus
2276 engine
With a german fuel and wasted spark kit from the dubshop
Thanks everyone for your help.
