My question is: does MS require a dedicated/isolated/fused (and ign. switched) +12V input directly from, the battery for a "clean" voltage input?
Right now, I'm looking at 3 main feeds coming off the battery + terminal: starter cable; adjacent to the battery a 4-terminal fuse box feeding a cooling fan and electric fuel pump (Bosch 044) relays - so only using 2 of the circuits, and a mega-fuse (175A) feeding the main chassis electrical system and American Autowire fuse panel.
What I'm planning is to come from the mega-fuse up to a buss bar at the AA fuse box location, under the dash. Off the buss bar I planned to feed the AA fuse box, MS +12V main power feed, +12V ignition coil feed, +12V boost control valve and a set of fog/driving lamps - all through separate fuses and relays.
Will these other devices coming off the buss bar affect the operation of MS, or am I just overthinking this? I was concerned with momentary V drops when say the light system and cockpit heater fan come on - screwing with having a steady +12 feeding the MS. Or is this not really an issue?
That's why I separated out the feeds to the high current draw fuel pump and main cooling fan - not wanting those, especially the fan turning on and off, to affect power input to MS.
I'm also using a ground buss bar at the fuse box to tie multiple grounds together for return to the battery, although in this case I do plan to run a dedicated ground from MS directly back to the battery.
My plan sound, or needs work?
Jeff
