MS1 v3.0 board. VR 36-1 wheel from CB performance. Sensor aligned on tooth 8 while at TDC.
I am using 2 BIP 373 for my triggers, off of the LEDs. Center LED is set for IRQ trigger. All 3 are blinking, The trigger leds do blink alternatively.
I am hoping someone can look at my msq and double check it for me if I made any obvious mistakes that could cause it to only fire half my coil.
Also I have it set to use table, but when I checked with timing light, I didn't get any advance. My spark map is embarrassing. (Before the upgrade I was running with a 009, so I copied that as my starting point.)
Trigger angle I am still very confused on what it should be. see http://www.shoptalkforums.com/viewtopic ... 6&t=148552 for that question.
Look at my MSQ please ?
- Thorkhild
- Thorkhild
Re: Look at my MSQ please ?
I have been having troubles getting the engine to fire, plagued by crossed wires, bad firewall connections, ignitor grounds, and lastly a little extra solder. I wasn't sure if my config was bad, but I did look at my ecu one more time.
I ended up double checking my solder job for the second ignitor and I had shorted the top of r29 to the bottom of r27 when I added the wire for Spark B.
After fixing the solder job, re-installed. Turned the key and she started right up !!!! I am so excited she runs now !!! Too bad I am about to start a long stint of work away from home so I won't be able to drive.
