Vibration of the front end
Posted: Fri Feb 12, 2016 8:22 am
by halimjimmy
When I drive my 74 standard Beetle on 40-45 MPH I feel that the front end vibrate . Does it need alignment?
Thanx
Re: Vibration of the front end
Posted: Fri Feb 12, 2016 12:49 pm
Alignment doesn't cause vibration, tire/wheel balance or out of round/eccentricity does.
Posted: Fri Feb 12, 2016 6:16 pm
by Bruce2
Two things that can contribute to this are wheel balance and your steering damper.
You can try rotating the wheels. Two ways, one is to take out all the wheel bolts and turn the drum by ΒΌ turn, then put the bolts back in. Repeat two more times if it doesn't work.
Or, swap the front wheels with the rears.
If it's been a long time since your wheels have been balanced, have them done again.
Take your steering damper out and see if it's working right. Likely it's shot.
Posted: Sun Feb 14, 2016 8:58 am
by halimjimmy
I did rotate the tires but the vibration still exists
