2919cc drag motor what size carby's and exhaust
mikeatshiloh
Post by mikeatshiloh »
Hi Guys I have been reading here for a while now. I have a few questions that I hope somebody can answer. I have collected all parts needed to build a 2919cc oxyboxer motor for our drag bug, I would like it to rev to 8000rpm so will need to know what size exhaust is required I'm thinking 2 1/8 and also carby's to feed it. I don't think my 51.5 IDA'S with48mm vents will be big enough? I don't know if it can be done, but is it possible to run 2 750 cfm square bore holly's with two throats feeding each cylinder. I can make the manifolds but I just don't know if it would work. Does anyone know if this has been tried before. 58 or 62mm carby's are way to expensive and I already have the holly's. Thanks in advance for any help Mike.
pocketrocket
Re: 2919cc drag motor what size carby's and exhaust
Post by pocketrocket »
If you are going to build that big of a engine. Whats another $3500 for the 58mm or 62mm carbs? What cam are you using? What heads did you get?
Post by Chip Birks »
I know a guy that has some 58mm throttle bodies that might be available...if you were willing to go the efi route.
mikeatshiloh
I have been collecting parts for this motor for a few years now. So as I said I already have the 750 holly's, that's the reason for asking about them. I have got an fk 89 cam for it and autocraft 910 heads with 50 inl and 40 exh valves which should be big enough. We are not thinking of trying efi at the moment. Mike
5.0 Chero
Post by 5.0 Chero »
Sorry but their is no way you need or could ever use 1400 cfm for that small of a motor
a 3000 cc motor running 10000 rpm at 100% VE would only need 530 cfm
mikeatshiloh
As far as I know a 51.5 ida is capable of flowing 300+ cfm per throat and that is not enough flow for a 2919cc. I think it has some thing to do with individual runners and not enough continuous flow, vacuum thru a single cylinder.
