Anyone else set this up? This is what I came up with....using a log file and getting the TPS value at 90kpa through the RPM zones.
Does it look like it should? Yes, no, maybe?
ITB Switchpoint settings
- grelland
Re: ITB Switchpoint settings
I see this quistion is quite old, but since you had no response, I will post my settings.
This is on my 2110 oxyboxer with CB Los Panchitos heads and dual 38mm ITBs from VW Speedshop / Mario.
Roy
Roy
thanks, that helps me out!
