I want to do the same for my setup. How exactly do I wire in those capacitors ? and are those values the ones I should use ? a 47 micro farad, and a 1 pico farad. What voltage rating should I use ?supaninja wrote:
so it looks like all my gremlins were caused by noise from the alternator. A 47uF cap to the power in and a 1pF across the boot load and i'm back in business. i probably could have gotten away with a small power cap since its shunting about .4v to the MS but it will work. got most of the idle dialed in but i ran out of gas.![]()
Anyways one problem fixed.
Eric
