Wideband O2 sensor for my Innovate Motorsport LM-2 (and ultimately EFI).
Not so concerned about location for Innovate testing, as that will be done ad-hock then sensor removed.. But when its EFI this becomes a permanent install.
All of these locations would have the sensor pointing sideways (3oclock position, maybe even 2oclock)
My thoughts:
A
Pros:
[*]Hidden from sight/wandering hands (car is a weekend warrior anyway, so low risk)
[*]Far from tailpipe exit so less likely to get a dodgy reading due to exhaust breathing fresh air in
Cons:
[*]Tight, not even sure if it will fit. To weld it nicely will require removing the header from the engine
B
Pros:
[*]Easy to get to/weld
Cons:
[*]Tidy wiring will require some creative thinking. Could potentially fit it on the opposite side.
C
Pros:
[*]Somewhat hidden, probably as much as A
Cons:
[*]To close to exit? So reading could be affected by fresh air in breathing (there is 18" to the exit from here, including the muffler)
I am leaning towards C, but am concerned about the breathing in fresh air risk..
Thoughts please!
