Wiring my Innovate MTX-L AFR guage...
I received my MTX-L and have a few questions regarding wiring this up so I can monitor the AFR and jet my IDAs. I may want to utilize a relay and am curious to know where I can find an appropriate relay? This will be going into a '67 type1. The wiring on my car is in good shape and is pretty close to the illustration in the Bentley manual for a '67. I already have some items powered from the fuse box and don't want to over load the fuses that are affected by the ignition switch. Thanks for any info.
Re: Wiring my Innovate MTX-L AFR guage...
I doubt that Wideband will draw enough to hurt anything.
Wire it off the horn fuse or the flashers. those don't get used much and with flasher you probably won't be driving anyways.
Thanks you, If I opt to run the relay should I mount it behind the dash or closer to the battery? Also what gauge wire should I use? Will the length of wire matter?
Ground it near where your ms3 is going to end up.
They will need to be grounded together to use together.
Thanks for all the input. I've had the wideband up and running for about six weeks now. Having other issues with the engine. I'll pick up tuning when those issues are taken care of.
