Dellorto FRD 34's or weber 34ICT
Hopping for advice on a twin carb setup for a 1600 going into a British buggy so space is tight and don’t really want to cut the body about thinking ether Dellorto FRD 34's or weber 34ICT. I have head that the Dellorto stay in tune better but can be a problem low down
- Jadewombat
Re: Dellorto FRD 34's or weber 34ICT
Weber 34 ICTs are junk even new right out of the box. It's the linkages that get out of tune. Get rid of the mechanical ones and go with a cable link system.
Thanks Jadewombat didn’t know they did a cable linkage, do you have any info on them a link maybe?
- Jadewombat
Here's one:
http://www.thesamba.com/vw/classifieds/ ... id=1381017
There may be others on the market or contact Pile on here. I have no experience with these though as I use single throttle body systems. Good luck.
