Wideband O2 placement for turbo
bug_n_67
Post by bug_n_67 »
Just wanted some feedback on where to put my O2 wideband sensor. I've attached a photo where I was going to place it, is this ok
Passatman
Re: Wideband O2 placement for turbo
Post by Passatman »
If you are going to, use a heat sync to protect the sensor.
Vee Dub Nut
Post by Vee Dub Nut »
I've mounted two in that position without a heat sink with no issues.. Give it a shot
Fightin' Texas Aggie Class of 2006
67 Beetle
74 Transporter (SOHC EJ25)
See all my VW pics on Instagram @ vee_dub_nut
miniman82
Post by miniman82 »
You lose so much heat through the primary tubes it won't be a problem, mine's in the same spot and it's never given me any troubles.
volksbugly
Post by volksbugly »
You are suppose to mount the o2 sensor below horizontal ie so where the electrical pug is pointing downward just a little. This is to protect the sensor from burning out when you start it in the morning and its got condensation on it.
volksbugly wrote:You are suppose to mount the o2 sensor below horizontal ie so where the electrical pug is pointing downward just a little. This is to protect the sensor from burning out when you start it in the morning and its got condensation on it.
You are thinking backwards... Sensor has to at or above horizontal, vertical is best (sensor pointing straight down) Bosch recommends 10 degrees above horizontal at a minimum. http://wbo2.com/lsu/lsuinstal.pdf
The proposed location is probably OK (run an EGT sensor there temporarily to check temp under boost), the heat sink setups are typically used for "upstream" or near the ex port WBO2, but an opton if the EGT probe says the temp is too hiot under boost.
volksbugly
Ohh you are correct! Sorry for the bad info. Carry on!
