im back
stkmtr
im back
i cant get my old name and password to work. It was stkrmtr from 2003 but im back, whats up piledriver and all my old friends...it been awhile, im finishing my 67 and all i need in some cut to length al pushrods from aircooled.net, John connoly, sorry I quit making those parts for you suddenly....long story.but im back and changed my lifestyle for the better. whats the best way to cut these pushrods
Re: im back
Welcome back!stkmtr wrote:i cant get my old name and password to work. It was stkrmtr from 2003 but im back, whats up piledriver and all my old friends...it been awhile, im finishing my 67 and all i need in some cut to length al pushrods from aircooled.net, John connoly, sorry I quit making those parts for you suddenly....long story.but im back and changed my lifestyle for the better. whats the best way to cut these pushrods
In a lathe, ideally.whats the best way to cut these pushrods
...lacking that Jake suggested an arrow shaft cutting jig, others have said it works well.
You could probably rig something that works decent with some angle iron and a thin (reinforced) cutoff wheel on a dremel.
You should be able to PM doc and reset your passwd.
Buggsy
Re: im back
Tubing cutter, just like you would use for brake line or fuel line.
shepherd
Re: im back
Yes, and if you have any doubt, get a new, sharp wheel for it. Tighten a wee bit at a time, so you distort the tube as little as possible, and to leave a very minimal burr. I just did a set this wayBuggsy wrote:Tubing cutter, just like you would use for brake line or fuel line.
- Chip Birks
Re: im back
I do it this way every time. Works very well.Piledriver wrote: Welcome back!In a lathe, ideally.whats the best way to cut these pushrods
