Good day all,
Does anyone know where i can find t4 center main adapter bearing to buy.
- Chip Birks
Re: t4 center main adapter bearing
For type 1? Adapting to t4 center main on big stroker? Jaycee maybe?
Ah! I finally got that info from jaycee. Well what I want to do is use the bearing in my waterboxer engine since I was told that both engines use the same main bearing ( number 1 is actually t4 size ).
Rocky Jennings sells them, IIRC they are from a BMW.Passatman wrote:Ah! I finally got that info from jaycee. Well what I want to do is use the bearing in my waterboxer engine since I was told that both engines use the same main bearing ( number 1 is actually t4 size ).
