can anyone identify these roller tip rockers??
bens collision
Post by bens collision »
i picked these up at the local vw parts store, i dont know anything about them but you can see a 1.52 and i swear it looks like comp cams stamped into them?? ive never run ratio rockers but the most ive seen for vw is 1.4. i was hope someone might have seen these before and even if they havent give me some info on what it takes to run somthing like this and what to expect, if they are 1.52 is it too much, will i loose bottom but gain top end etc etc? they would be going on an turbocharged 1835 in a dune buggy. thanks
buildabiggerboxer
Re: can anyone identify these roller tip rockers??
Post by buildabiggerboxer »
Any underside pics?
benito26
Post by benito26 »
Look like old school Pauter, what spec cam and heads you thinking of running with em, what's the rest of the combo? I like GB309 with 1.5 rockers
1835 thin wall or thick wall barrels, thin wall don't like boost
craigvwdude
Post by craigvwdude »
Comp Cams roller tip rockers made for a sb cheby or sb ford with some sort of adapter plate.
bens collision
benito26 wrote:Look like old school Pauter, what spec cam and heads you thinking of running with em, what's the rest of the combo? I like GB309 with 1.5 rockers
you are correct, they are pauter's! i talked to the man himself on UAC
