New clutch problems! Rlr black magic.
I just put a Kennedy stage 2, 2200psi pressure plate with a Ron lummus black magic clutch in my turbo bug. I had a stock clutch and it wouldn't hold at all. Now, when I go to take off the car hops like crazy. Almost like wheel hop. After I get going past the jumping the clutch is awesome. Anyone have any idea what the problem is?
- Henryhoehandle
Re: New clutch problems! Rlr black magic.
Hydraulic or cable??
- Fiatdude
Well, stop wheel hopping the car unless you like broken axles -- -- the cure -- stiffer torsion bars (min 28 better 31) and a set of QA1's multi adjustables shocks from Lumus -- the price of HP
I always had stuff falling off from hop
http://i586.photobucket.com/albums/ss30 ... eshake.jpg
http://www.youtube.com/watch?v=iAGKvzF9QNg
- fusername
took me a minute to figure out that picture! awesome.
As for wheel hop, solid mounts are what fixed mine once* and for all. I had already caged the car, and tied the frame horns to the rear bumper/cage. those helped, as well as the rear engine hanger, but the solid mount was the nail in the coffin for sure. Mine was SA.
*cheap solid mount came loose twice before it "settled in" to its final shape and held torque.
It's a cable clutch. The more I drive it the better it seems to be doing on the takeoff
- Corysvdub
Did you have the flywheel surfaced? If not, the disc is going to take awhile to break itself in. I had one that would slip a bit before it wore itself in. They are great discs and grab well, car would do second gear wheelies.
Type 3 Subaru powered EJ25
If it is actually wheel hop then you will need a solid trans mount as said above and get some kind of Kafer brace. At that point you can figure out how to deal with your suspension issues. There are plenty of people who have made stock torsions work. Controlling the suspension travel and rebound is the key.
I read recently FJCamper reported similar sounding issue on the Blitzwagen, traced to a nonstd cause:
...issue with a brand new clutch/PP combo-- rivets on PP interfering with rivets on disc.
- juki48
I've heard the black magic can chatter like a bitch on the road, especially when new. My trans builder recommended to not use one for that reason. he did recommend them for drag though.
Riley
74 Ghia 2276 Turbo MSII Extra
67 Beetle in restoration
Manx Style buggy 1600 stock
