Stock Fan or Race Fan?
Jim Ed
Post by Jim Ed »
I want to replace my fan.
I have a stock engine.
Would it be better to go ahead and get a welded & balanced race fan?
TIA! 1600 btl
ainokea
Re: Stock Fan or Race Fan?
Post by ainokea »
The option is yours. The race fan is is a good way to go if you think you need it. The stock fan is is also more than adequate for a stock engine at about half the price of a race fan. Is there any paticular reason why you're considering this change? I don't think a stock engine will turn the kind of RPM's that would require a race fan. Like I said, it's your choice.
Ainokea
Jim Ed
Post by Jim Ed »
ainokea wrote:The option is yours. The race fan is is a good way to go if you think you need it. The stock fan is is also more than adequate for a stock engine at about half the price of a race fan. Is there any paticular reason why you're considering this change? I don't think a stock engine will turn the kind of RPM's that would require a race fan. Like I said, it's your choice.
Ainokea
I was thinking that my stock fan is about 40 years old and wanted to replace it to save possible troubles.
Now I am thinking of keeping it.
E_bug
Post by E_bug »
Unless you are feeding the fan snow and rock salt it will prob last another 40yrs.
My welding sucks .
volkaholic1
Post by volkaholic1 »
check around the hub for small cracks, check for loose fins, put it on the gen and spin it, does it wobble? If no to everything, it is probably OK, if any issues, replace it. Unless you plan high rpm, the welded and balanced fan is probably not worth the extra bucks.
