Speedo idiot plastic lens warped due to heat
Posted: Wed Sep 26, 2012 6:52 am
by sagaboy
My speedometer idiot signal lamp plastic lens is totally warped over 40 years of exposure to the bulb heat. Can anyone offer a solution, thanks.
Re: Speedo idiot plastic lens warped due to heat
Posted: Wed Sep 26, 2012 6:54 am
by Stray Catalyst
You could switch to LEDs, or just use gel filters from any theater supply place. Or leftover plastic from a broken tail light lens.
Posted: Wed Sep 26, 2012 7:22 am
by SANDFLEA
Late model speedos can be found for so cheap I think I would just
change the Speedo. (Thats coming from a cheap ass)
Posted: Sat Sep 29, 2012 7:35 am
by sagaboy
Stray Catalyst wrote:You could switch to LEDs, or just use gel filters from any theater supply place. Or leftover plastic from a broken tail light lens.
Good suggestion.
Problem solved. I found an old piece of green glass theater spot light filter and cut it to size with a glass cutter.
