mahle vw piston orientation
maxyray
Post by maxyray »
Hi All,
I'm just about to install a set of mahle forged 90.5 pistons.
My question is this...
Is there a top and a bottom to a Mahle piston? I've been told that the piston pin sits off center.
I know that the arrow on the piston points the the flywheel.
Max
Re: mahle vw piston orientation
Post by Marc »
Yes, the wristpin is slightly offset to one side - installing them with the arrow pointing towards the flywheel orients them correctly in relation to the direction of rotation to reduce piston "slap" and noise.
There's no "top" or "bottom" to concern yourself with unless the piston tops have been notched for valve clearance.
maxyray
Post by maxyray »
Ok got it.
:D
Max
