lost hardware
JHHeiger
lost hardware
Post by JHHeiger »
I somehow misplaced the two top engine to transmission bolts and nuts. What size am i looking for? I know the nut size in 17MM
thanks, J
Re: lost hardware
Post by Marc »
AutoSticks use longer hardware, the following applies to 4-speeds.
The LH bolt is 70mm long, the RH is 110mm. Thread is m10x1.5
Depending upon the year of the car/transaxle/starter/engine either bolt may be hex- or D-headed. You can always use a hex-head bolt, but most starters have "nibs" to hold a D-head from spinning which makes it easier to tighten the nut. Mid`60 thru 1970 trans cases have nibs for the LH bolt as well (they were dropped in `71 with the introduction of the DP engine that has a threaded steel insert in the case for the LH bolt).
P/N for the 110mm D-head is 111 199 101
The 70mm D-head is N 010 470 7 (AKA N104707)
