HELP ! Adjust Ring & Pinion
coxcarrera
Post by coxcarrera »
Hello,
How do you adjust the backlash between ring and pinion if not have the Ro registered ??
Dougy Dee
Re: HELP ! Adjust Ring & Pinion
Post by Dougy Dee »
Use a .60mm shim on the pinion to start.
That should get you started.
How you measure the distance between the side covers is different for SA and IRS.
I usually do it before installing the pinion and shoot for .007 preload.
IRS is easy with a dial indicator and patience.
SA is a treat without proper tools.
Originally I had a stock diff I modified to slide thru the ID of the diff brgs.
Measure with a dial indicator. Worked great.
Now I have the correct tool. Works great too.
r1mudman
Post by r1mudman »
Dougy Dee wrote:Use a .60mm shim on the pinion to start.
So how are you getting the dial indicator into contact with the ring gear to measure backlash on an IRS? I am looking at the drain plug as an option but haven't gotten there yet. Is there an easier way?
