I drove the Bug home from work, parked it, now BOOM the driver's side rear axle is locked up completely. The engine won't even move the car; the right tire just starts spinning on the concrete.
This isn't a brake problem. I backed the shoes off as far as they'd go, still locked up.
What would cause one axle to lock up?
- MinamiKotaro
'67 Beetle, 2276
MS-1 v3.57
MS-1 v3.57
- david58
Re: What would cause one axle to lock up?
swing or irs?
May be true, but you won't know conclusively until the drum is off (something could have come apart in there that's keeping the drum from turning even with the adjusters backed off).MinamiKotaro wrote:...This isn't a brake problem. I backed the shoes off as far as they'd go, still locked up.
Anything special about the differential, or is it all stock?
- MinamiKotaro
Swingaxle.
4-spider diff.
I'm going to take the drum off tomorrow. You are probably right. Something must have broken inside when I applied the parking brake and gotten wedged between one shoe and the drum.
4-spider diff.
'67 Beetle, 2276
MS-1 v3.57
MS-1 v3.57
I've had the shoes rust onto the drums/freeze up in wet climates after a week.
What kind of 4 spider diff? There are two styles as far as I know, the Superdiff and the Beef-a-diff with the latter being more problematic from what I understand. Overly simplified; it is a bolt in conversion adding a second set of spiders to the two spider diff that is stock with most VWs while the Superdiff is a whole new carrier and is stronger. A picture of the Beef-a-diff conversion parts: http://www.thesamba.com/vw/classifieds/ ... id=1197983
- MinamiKotaro
It's a Superdiff from Weddle. Most of the trans is made of Weddle parts.
'67 Beetle, 2276
MS-1 v3.57
MS-1 v3.57
- MinamiKotaro
The metallic brake shoes has rusted to the drums. Nice to know my trans is good.
'67 Beetle, 2276
MS-1 v3.57
MS-1 v3.57
