Axle pop out?
Posted: Mon Jul 23, 2012 10:13 pm
by craigvwdude
Fellas,
was putting in a axle seal kit on my 67 yesterday (pass side) and when I took off the bearing cover the axle popped out about and inch. Is this ok? Or did the fulcrum plate slip out?
I have absolutly no experience with transmissions.
Help!
Craig
Re: Axle pop out?
Posted: Mon Jul 23, 2012 10:30 pm
by Bruce2
Can you push it back in by the exact same amount?
Re: Axle pop out?
Posted: Sun Aug 05, 2012 4:01 pm
by Henryhoehandle
And, if you turn it forward and backward you can feel if it is out of the plates or not.. But like Bruce said, if the plates are out then it wont go back in all the way..cross your fingers!
Re: Axle pop out?
Posted: Sun Sep 30, 2012 9:21 pm
by Hotrodvw
Yikes..........I was hanging the axles on my dad's new trans here a while back, and rolled it over w/o thebearing cap on............axle slipped out. I got extremely lucky, and slid it back in with out the fulcrum moving. Fortunately, I greased them up so they'd stay put while I slid them in the first go around. If you can get it back in where it should be, I'd say you got lucky!.
