1300cc vs 1200cc
1300cc vs 1200cc
Hi all.I read that the bore on 1200cc piston is the same as that of a 1300cc piston.I am rebuilding an engine and need to replace the rings,is there a problem if I place 1300cc piston rings on a 1200cc piston?
- sideshow
Re: 1300cc vs 1200cc
Rings are normally sold by bore & width, not stroke.
So I would worry about if I need "big bore rings" and they came in a stock 1300c box. The bently tells you wear limits and gap desired.
As a rule, 1200 rings are 2.5x2.5x4mm and 1300 rings are 2x2x4mm...so you should be able to interchange the oil rings, but the compression rings most likely will be the wrong width.
Ok..thanks guys for all your replies.
