Porsche brake piping layout
Posted: Wed Jun 13, 2012 12:22 pm
I've been reading, and reading and again reading, and yet I can not get to a conclusion. I installed 924S/944 disk brakes front and rear. As I have been documenting, I decided to plumb the brake lines in diagonal. Yet I think this is not a good solution for my car. Everywhere I can find info on front engine/front drive cars (to which the diagonal brakes are recommended) and on front engine/rear drive cars (to which front and rear circuits are recommended). Nothing on rear engine/rear drive cars. I tend to think it would be better to have separate front and rear circuits arrangement.
One more thing that bothers me: these Porsche brakes have larger diameter pistons on the front and smaller diameter pistons in the back. But these were designed for a front engine/rear drive car. Of course, they are far better than the old drums that I had, but could this be a problem? Maybe the light front end of the beetle leads to the front wheels to lock (according to Pascal's law, there will be a higher force on the front pistons, with the larger diameter, than on the rear pistons).
The last thing that I want to understand: how the brake master cylinder works: which circuit is pressurized first and which last? Maybe the connection of the front/rear to the circuits on the pump one way or the other can overcome the problems mentioned before.
Which configuration should I use (diagonal or front and rear)? and in case front and rear arrangement, to which circuits on the pump should each be connected?
