SCAT Zero Mile Long blocks
DamianG
Post by DamianG »
Hi All
Just stripped my 1600 down for a rebuild and I have the dreaded crack behind #3.
As I need a new case, and would rather put all new parts, I've been surfing around the net for part prices. It seems the best deal I have found so far is the Scat zero mile long block. http://www.scatvw.com/master/long_block/. I'm after peoples opinions of their quality, and how well they last.
I dont mind stripping it down and giving it an internal check if needed, but it sure looks like a cheap way to get everything I need for a long block cheaply.
cheers
Damian
kangaboy
Re: SCAT Zero Mile Long blocks
Post by kangaboy »
I know the GEX motors have a horrible rep, i think the SCAT motors are a little on the rough side too. They are assemblers, not builders. I dont want to promote another vw forum, but thesamba had a vendor section with consumer reviews you may want to check out. Also use the search forum on this site and see what happens when you type in SCAT.
DamianG
Post by DamianG »
kangaboy wrote:I know the GEX motors have a horrible rep, i think the SCAT motors are a little on the rough side too. They are assemblers, not builders. I dont want to promote another vw forum, but thesamba had a vendor section with consumer reviews you may want to check out. Also use the search forum on this site and see what happens when you type in SCAT.
thanks Kangaboy. I did try searching these forums and samba, but didn't find much info on the longblocks. I just found the scat kits and they seem like really good value. Even better than this is the case that I have I though was cracked and it turns our it is just superficial crazing on the case from being in the weather, so I'm gonna go rebuild that into a 1600dp turbo.
cheers
Damian
