kpaix kpa
kpaix kpa
kpaix kpa - some body splain this to me. Kpa according to google is kilopascals per square inch, which I can convert to make english out of. Google doesn't know what kpaix is, and neither do I. Why is it important to megasquirt, or myself?
- supaninja
Re: kpaix kpa
I got a cool conversion app on my phone.
14.7psi (atmospehere) equals 100KPa
8.7psi equals 60 KPa (my idle vac)
5 psi equals 35KPa (max vac when i'm decelerating and engine braking)
now the same stuff but in inHg
30inHg equals 100KPa (atmosphere)
18inHg equals 60KPa
10inHg is 35KPa
I hope that helps visualizing everything, I like KPa better then inHg or psi but I have used them before too.
18inHg equals 60KPa
10inHg is 35KPa
viewtopic.php?f=14&t=140387
Re: kpaix kpa
that helps make sense out of what I am looking at for sure, so far I have been kinda letting VE Live do its thing, but I'd like to better understand what it is that it is doing also. Thanks for the help- The car is more and more fun to drive every time I run that program. To answer one of my previous posts... well worth the $50.00 I spentsupaninja wrote:I got a cool conversion app on my phone.
18inHg equals 60KPa
10inHg is 35KPa
Re: kpaix kpa
Yep, a good way to visualize it is the 100kpa line all the way across is WOT for an N/A engine. Anything higher than 100 would be boost pressure, anything below manifold vacuum. 14lbs per 100kpa, 7lbs every 50kpa. I fart in your general direction!
Re: kpaix kpa
miniman82 wrote:Yep, a good way to visualize it is the 100kpa line all the way across is WOT for an N/A engine. Anything higher than 100 would be boost pressure, anything below manifold vacuum. 14lbs per 100kpa, 7lbs every 50kpa. I fart in your general direction!
Re: kpaix kpa
Have you (at your peril ) used mapdaddy to log the pressure differential yet????????miniman82 wrote: I fart in your general direction!
Re: kpaix kpa
hmmm... nope. New one to me.. Mapdaddy?
- Dale M.
Re: kpaix kpa
Actually 100 kilopascals (kPa) is 14.503 psi or 1 "bar"...
If you need measurement, volume, pressure, decimal/metric and lots of other conversions...
http://joshmadison.com/convert-for-windows/
Dale
Dale
