412 window rubber.....
vdubinluvin
Post by vdubinluvin »
I'm going to start the redue on my 74 412 and need to figure out what to do with the window rubber. I know you can use bus rubber for the front and rear glass but what about the quater rubber? I want to retain the molding also any hints? Ray?
vdubinluvin
Re: 412 window rubber.....
35 views and nothing........:-)
bradey bunch
Post by bradey bunch »
I talked to my glass guy and he said he could get me something, have you tried a glass shop?
vdubinluvin
I have talked with a few but no dice
type4ever
Post by type4ever »
Send an e-mail to [email protected] in Holland.
I think they can help you.
Ton
wshawn
Post by wshawn »
type4ever wrote:Send an e-mail to [email protected] in Holland.
Ton
Got mine from there and a great fit
vdubinluvin
Ton
Thanks for the tip just messaged them :D
Your eaten is the same color as mine L98 I believe
raygreenwood
Post by raygreenwood »
Sorry for the delay in answering. By next month i will have my car back in my hands and out of storage. there is a very simple method i cooked up to reliably use type 1 or early bus rubber to replace type 4 rubber. It requires making an adaptor/gripper/spacer insert that goes against the vertical side of the ledge or channel. If you look at all the seals in cross section, thpough the dimesnions vary they are enough the same shape that they can work if cany major gaps are filled. The most glaring major gap between type 1 and type 4 rubber is where the little flexible ribs are that squash against the vertical sideo fthe channel. the type 1 rubber is not as deep here.
What I will use is ribbed industrial V-belt rubber that has been poprivted and sealed against the vertical wall of the channel. I have several rubber suppliers that will sell varying widths by the foot. Nore to come. Ray
dubsonjim
Post by dubsonjim »
any update on this?
raygreenwood
Not yet. Still under the front end. Ray
