8 or 9mm valve stem.
Onlyvw
Post by Onlyvw »
I am building a quite serious wbx 2223 (96.5x76) turbo engine and will change the valve sizes. Original wbx has 9mm valve stem on exhaust (probably because of the sodium) I will now order a custom set from Si valves. What is recomended 8 or 9mm valve stem on exhaust??? Is it also recommended to cut the guide in the exhaust port???
buildabiggerboxer
Re: 8 or 9mm valve stem.
Post by buildabiggerboxer »
Change to 8mm stems as you're changing valves any way. many drag cars now run 6 or 7 mm stems, but they must have a short life, and yes, you can remove the guide boss OK, but i would just streamline and flow it, personally i use a big beefy exhaust guide with turbo use, rather than a streamline and thinned race type guide, Ive had these crack and bits break off at the thin end.
Onlyvw
Post by Onlyvw »
Thanks for answer I then will change to 8 mm stem.
Would you have cut the valve guide or just let it be for street use??? Engine will run on E85.
tencentlife
Post by tencentlife »
Wbx did not use sodium-filled valves, they're just a welded valve with a 9mm stem.
If I was boosting I would stay with that size. A narrower stem would offer a flow increase that would be more significant in a NA setup, but with the more extreme heat of a boosted app I would favor the stronger valve myself for longevity, and the larger stem offers more heat-transfer area with the guide; that's even more significant if you are trimming the guides. The 8mm will work just fine I'm sure, I think your choice comes down to how long you want to go between valve jobs.
fastback
Post by fastback »
tencentlife wrote:Wbx did not use sodium-filled valves, they're just a welded valve with a 9mm stem.
how shure are about this?
tencentlife
100%.
There was good reason to use a Na exhaust valve in the aircooled heads, but no reason to in a watercooled head. Manufacturers don't generally waste money on such expensive parts when there is no need.
But don't believe me. Take an OEM wbx exhaust valve and saw thru the stem. Solid steel all the way thru.
fastback
Post by fastback »
and so i did :D
seem to be stainless at the seat end. as it is non magnetic up to the weld splice
tencentlife
I've posted the link to this article a few times, it's a good explanation of valve metallurgy:
http://www.enginebuildermag.com/Article ... lloys.aspx
