http://www.harborfreight.com/10-30-psi- ... 94244.html
Something like this but mine is 2 burner.
http://www.zimbio.com/Home+Improvements ... e+Tank+Top
Ironically that is exactly what some of the 4ft square and larger ovens use.....Steve Arndt wrote:Body shop IR panel heaters work for big parts.
Propane heater would be a waste of time.
I bolted an old Sears full size oven to a shopping cart from k-mart. Wallah, portable oven. :)0
Thanks will doSCOTTRODS wrote:I got my latest Electronic controlled Kitchen oven (for powder coating) for free off craigslist. One of the top burners was trashed so they bought a new oven and was giving this one away..... Powder coating, you don't need the stuff on top, so it works out very well for me.
GE TrueTemp is very accurate for home ovens.... When you get (or if you get) a kitchen oven, to work with, I recommend laying a pizza stone or an un-glazed floor tile, on some legs just above the burner on bottom, so it helps even out the heat across the whole space. I just cut some 2 inch pieces of 2" angle iron and made "tents" to set the pizza stone on in my oven. Helps immensely. Also retains heat so you can open the oven to check part metal temp, without losing too much heat. Recovery time is shorter.
It's just a matter of controlling the temp closely..... I can halpe with homemade oven controls too. Using a PID from ebay, and a Contactor or an SSR, it's pretty cheap to do. You can go spendy too, like me, but I am a bit into Overkill,... I understand you can never have enough.
Like I said,... I can help you if you want.. just PM me and I'll see what I can do.
Steve Arndt wrote: The hardest part is transferring a powdered part to the oven without dislodging powder (and static) and screwing it all up).
s
Great Point - If there's ever a doubt, I always do the same "Dry Run" loading parts. Last thing I did that was that close was within a half inch of the door as it shut..... And the part touched the back all of my Large Oven.... That touching part was to stay un-coated, so it worked out pretty well.... another half inch and I'd have had a whole new process to work out I think.Steve Arndt wrote:Another trick I've been using: Get your needle nose and pliers that you will use as tongs in the hot oven. Put stainless wire on your parts to prepare them for hanging in the oven. Make a dry run of placing the parts into the oven pretending that the part is powdered already. If you can't get it hung up in your oven now, then you won't be able to with powder on it. I made little wire hooks that hang directly off the top burner element. I make little looks in the wires on my parts. Then I just slip the loop/wire onto the little hooks.
