bracket
Posted: Mon Sep 19, 2011 6:29 pm
by dave7273
Can someone tell me what the bracket looks like that holds the E- brake cables to the E- brake handle?
Thanks
Re: bracket
Posted: Mon Sep 19, 2011 6:54 pm
by SCOTTRODS
dave7273 wrote:Can someone tell me what the bracket looks like that holds the E- brake cables to the E- brake handle?
Thanks
I know this is a type I forum, but,... for what year model car are you inquiring this info?
Re: bracket
Posted: Mon Sep 19, 2011 8:13 pm
by Marc
Through `64 there was no equalizer plate, the cables simply attached through loops welded to either side of the handle. On the later levers (there are `65-`67, `68-`72, and `73-`79 versions although some sellers only offer one or two) there's a pin sticking up that the equalizer plate pivots on. If a cable breaks, the pin soon follows...but there's no need to replace the lever when it does, simply drill an 1/8" hole about ½" deep and drive in a new pin (welding rod or even a nail works).
The plate is no longer available from VW, but Wolfsburg West sells a reproduction:
Re: bracket
Posted: Mon Sep 19, 2011 9:06 pm
by dave7273
Kinda late now but it's a 73 chassis and 72 body
Thanks a bunch
Re: bracket
Posted: Mon Sep 19, 2011 10:00 pm
by Marc
The shifter was moved back slightly in `73, necessitating shortening the e-brake lever a little so you can get your thumb on the button with the shifter in Reverse. They also used a different pawl for the e-brake warning lamp, the lever has a "window" on top to accomodate the taller pawl.
