It's not to bad. I don't need to pull the header or turbo. I do need to remove the fuel rails and injectors. Then pull the wiring back, pull off the up pipes, cap off the full flow lines and yank
Wiring wise I only have a hand full of things that need to move. IAT, Coolant, TPS, VR, Hall dizzy, Boost control.
I can have it out in a couple hours if I need to.
