Workshop and Tool Organization
Here is a neat trick to organize your air tools.
Re: Workshop and Tool Organization
Nice idea but I would add some kind of guard in case of accidental brushing against the storage bracket. Too easy for one or more of them to fall and either bend a shaft or in the case of a cut off tool damage the disc and have it come apart during use (personal experience here).
I don't think a guard is necessary, you can't make air tools go up hill. The table gets moved around the shop as needed. As rough as this 30 or 40 year old concrete is the air tools stay put.
chknlyps62
Post by chknlyps62 »
That is a good idea but I would add something that flips up over the ends to keep out dust, dirt and the debris from accidently sweeping the table the wrong way.
Two Wrongs Don't Make A Right...... But Three Lefts Do!
sideshow
Post by sideshow »
I use the same material, but store tools upright and screwed into the wall.
Near the door, blow guns, tire filling chucks...on the back wall less often used body tools.
Dale M.
Post by Dale M. »
Only real problem may be a with ends facing upwards all the dust, dirt, filings and crap in the world can fall into chuck insert (stud) and gum up air tool when you lube then periodically...
Dale
fusername
Post by fusername »
I'm with dale, but that just means ill put mine on the wall and not a tray that i might work on. like it alot
They have those little vacuum hose covers that could be slid over the open ends of the air tool quick disconnects; problem solved unless one goes on a trip and you don't. Thinking about it; no matter how you store the tools, the covers over the ends of the air tools is not a bad idea.
