found it at work but no one knows what its for?
the gauge reads up to 2000 psi
i put the end with the little bump under a forklift and stood my full 200lb weight in the other end with the "foot" on the ground, the gauge went round to about 150psi. any ideas guys?
MY JUNKYARD 1600T BUG IS NOW ON THE ROAD, THANKS STF USERS FOR ALL THE HELP!
SEE MY ENGINE BUILDHERE MY YOUTUBE CHANNELHERE
Looks like a portable scale of some type. What it's used for, I don't have a clue. Looks like it's missing a handle extension. I would bet the gauge reads in actual pounds. A nice tool to have in your tool bin. I made a Jack Scale to weigh stuff.
Marvin
Bugfuel wrote:very interesting. Old school as it may be
I'm used to an electronic /digital scale set, makes it faster but it's not as portable...
I'll give you $30 for it
Jan
I bet you would Jan.... Good to see a familiar name on here ( I even recognize the username)..... I suspected I might have gotten a call from you on my 56 convertible ad...... Sold it last weekend.
Oh,.... This would be "MUADIB" from the RAMVA newsgroup..... I still have the Dune Buggy for building, but got rid of almost everything else VW I owned... still part owner of ONE more car with John Willis.
I'll keep watching for more of the guys from RAMVA. Seems like I saw Max on here too.
That is a weight checker. use to check corner weight or weight at the wheel. we would line up the weight checker
at the wheel or rims edge and raise the chassis up to check the weight.
primarly use is for oval track cars.
I used it for a midget and sprint car until I could afford some electronic scales.
they are still available and still a quick way to check your corner weights
