So here we go, started with a 55 gallon drum dad got from work, I know wodge still has another drum that's mine still needs collecting, will tell you what we have planned for that one later on :p
And then we cut out at the top (We left the other holes in as these can be used for airline,vacuum setup, you will see in next pics)
The holes you can see
Hydroponic vents for arms, I did buy some pvc gauntlets from screwfix but they are not wide enough, But have found some better ones that they have in £8 mind you !!
Thats where we are now,
Screwfix = £7.78 toggle catches and gauntlets these are going back tho.
Tool station = £18.13 light, bosch cutting blades these are going back tho wrong ones, sickaflex, round vent.
Wilkinsons = £1.16 weather strip
Weather strip is for sealing against lip of the drum and lid we are going to make from the other oil drum, The vent is so clean air can be sucked in, The vacuum (i still need to get from screwfix) will suck all the particles etc into the vacuum, The sikaflex to seal the vents to the drum, Toggle catches for lid and there you ahve it, i have bought a blast gun syphon one from ebay. But i still need to get vacuum,perspex or window,steel
Will jet wash the drum out (before i empty the oil into a waste container
cheers Luke
