Oxyboxer build thread
Posted: Wed Dec 01, 2010 2:24 pm
Hello there.
I have been a lurker on this sub-forum for a while, but since I quite recently decided to start an oxyboxer project, I figured I could use the opportuity to share the progress with you, but also seek advice as I move along.
I have quite recently finished a long lasting EFI project on my curret engine, a 1835cc T1 that is running like a charm in my Ghia. here's a link to the thread on the fuel injected sub-forum: http://shoptalkforums.com/viewtopic.php?f=23&t=105351
I am located in Norway, so I will not have the possibility to have any parts machined at one of the experts in the US, but I have some contacts with the right equipment here, so I guess I will be fine.
The plan is roughly as follows:
wbx case with removed water jackets
stock 76.4mm crank
cima/mahle 94mm T1 p/c
EMPI 5.500 H-beam rods
relocated head studs
CB 2253 camshaft
SuperFlow heads
Pauter 1:1.3 rockers
Megasquirt EFI
Throttle bodies from Suzuki GSXR600
T1 Fan shroud
The target is good driveability with around 170-180 hp. Will be used as a daily driver, but occational trips to the drag strip and circuit course are likely.
The main reasons why I want to build an oxy-boxer is the fact that I like the idea of using original German case and crank as a base, then the fact that the case is in aluminum, and also the 5-bolt flywheeel mount.
I have mostly hand-tools in my garage, but I do have access to some machining tools in the shop at work, but I have no experience in using these...
This will not at all be a fast project, as I have some experience in projects taking its time... The Ghia took me 12 years to finish, the 1835 come 4-5 years... But I do really love these kind of projects, and the planning, discussions and solutions I come up with as I move along is just as rewarding as the end target.
So come on, give me feedback, and hopefully good advice as this engine is born.
Roy, Norway
stock 76.4mm crank
CB 2253 camshaft
SuperFlow heads
Megasquirt EFI
T1 Fan shroud
Roy, Norway
